小功率管
2N930 NPN LOW POWER 硅 晶体管 [53kb]
2N1613 NPN - 音频 output ,Video, Driver [NTE128][28KB]
2N2222A NPN General Purpose Amplifier [161KB]
2N3439 NPN 硅 PLANAR EPITAXIAL HIGH VOLTAGE 晶体管 [54kb]
2N3440 NPN 硅 PLANAR EPITAXIAL HIGH VOLTAGE 晶体管 [54kb]
2N3904 NPN
2N3906 PNP
2N5401 PNP 晶体管 [68kb]
2N5415 PNP 硅 晶体管 [67kb]
2N5416 PNP 硅 晶体管 [67kb]
2N5550 NPN 硅 晶体管 [69kb]
2N5551 NPN 硅 晶体管 [69kb]
2N6515 High Voltage-General Porpose amplifier [NTE] [23kb]
2N4921 NPN-中功率管[107kb]
2N4922 NPN-中功率管 [107kb]
2N4923 NPN-中功率管[107kb]
AF125 Germanium PNP 晶体管 RF朓F Amp, FM Mixer OSC [NTE160][22kb]
BC107 NPN-低噪声 (Comp.to BC177) [101KB]
BC108 NPN-低噪声 (Comp.to BC178) [101KB]
BC109 NPN-低噪声 (Comp.to BC179) [101KB]
BC148 NPN - 音频放大,开关 [NTE123AP][23KB]
BC177 PNP-低噪声 (Comp.to BC107) [101KB]
BC178 PNP-低噪声 (Comp.to BC108) [101KB]
BC179 PNP-低噪声 (Comp.to BC109) [101KB]
BC182 NPN -音频放大、开关 (Compl to BC212-BC214)
BC183 NPN -音频放大、开关 (Compl to BC212-BC214)
BC184 NPN -音频放大、开关 (Compl to BC212-BC214)
BC212 PNP -音频放大、开关 (Compl to BC182-BC184) [108KB]
BC214 PNP -音频放大、开关 (Compl to BC182-BC184) [108KB]
BC327 小信号 晶体管 (PNP) [Compl to BC337-BC338]
BC301 NPN 硅 planar epitaxial 晶体管 [Comp. to BC303] [73kb]
BC302 NPN 硅 planar epitaxial 晶体管 [Comp. to BC304] [73kb]
BC303 PNP 硅 planar epitaxial 晶体管 [Comp. to BC301] [80kb]
BC304 PNP 硅 planar epitaxial 晶体管 [Comp. to BC302] [80kb]
BC328 小信号 晶体管 (PNP) [Compl to BC337-BC338]
BC337 小信号 晶体管 (NPN) [Compl to BC327-BC328]
BC338 小信号 晶体管 (NPN) [Compl to BC327-BC328]
BC414 NPN-音频-开关 (Comp.to BC416)[NTE123AP][25KB]
BC416 PNP-音频-开关 (Comp.to BC414)[NTE159][26KB]
BC461 PNP High Voltage Amplifier & Driver [NTE189][23kb]
BC516 PNP -达林顿管, 大电流 (Comp.to BC517)
BC517 NPN -达林顿管, 大电流 (Comp.to BC516)
BC546 NPN-音频-开关 (Comp.to BC556) [57KB]
BC547 NPN-音频-开关 (Comp.to BC557) [57KB]
BC548 NPN-音频-开关 (Comp.to BC558) [57KB]
BC549 NPN-音频-开关 (Comp.to BC559) [57KB]
BC550 NPN-音频-开关 (Comp.to BC560) [57KB]
BC556 PNP-音频-开关 (Comp.to BC546) [55KB]
BC557 PNP-音频-开关 (Comp.to BC547) [55KB]
BC558 PNP-音频-开关 (Comp.to BC548) [55KB]
BC559 PNP-音频-开关 (Comp.to BC549) [55KB]
BC560 PNP-音频-开关 (Comp.to BC550) [55KB]
BC635 NPN 中功率晶体管 [Compl to BC636]
BC636 PNP 中功率晶体管 [Comp.to BC635 ]
BC637 NPN 中功率晶体管 [Compl to BC638]
BC638 PNP 中功率晶体管 [Comp.to BC637 ]
BC639 NPN 中功率晶体管 [Compl to BC640]
BC640 PNP 中功率晶体管 [Comp.to BC639 ]
BCY70 PNP 晶体管
BCY71 PNP 晶体管
BCY78 PNP 开关 晶体管
BCY79 PNP 开关 晶体管
BCY87 Matched 双 NPN 晶体管 in a TO-71- SOT31 metal package.
BCY88 Matched 双 NPN 晶体管 in a TO-71- SOT31 metal package.
BCY89 Matched 双 NPN 晶体管 in a TO-71- SOT31 metal package.
MPSL01 NPN-高电压、放大
MPSL51 PNP
MPSA06 NPN-高电压、放大 [NTE] [23kb]
MPSA42 NPN-硅 晶体管 高电压、放大 [882KB]
MPSA43 NPN-硅 晶体管 高电压、放大 (Comp.to MPSA93) [295KB]
MPSA56 PNP-音频 amplifier. switch [NTE] [25kb]
MPSA92 PNP-硅 晶体管 高电压、放大 (Comp.to MPSA43) [73KB]
MPSA93 PNP-硅 晶体管 高电压、放大 (Comp.to MPSA43) [73KB]
中、大功率管
2N3055 NPN- 功率放大. (Comp. to MJE2955)
2N6283 达林顿管, NPN-功率放大.(Comp. to 2N6286) [80K]
2N6284 达林顿管, NPN-功率放大.(Comp. to 2N6287) [80K]
2N6286 达林顿管, NPN-功率放大.(Comp. to 2N6283) [80K]
2N6287 达林顿管, PNP-功率放大.(Comp. to 2N6284) [80K]
BD135 NPN- 音频 功率放大,开关 (Comp.to BD136) [39KB]
BD136 PNP- 音频 功率放大,开关 (Comp.to BD135) [105KB]
BD137 NPN- 音频 功率放大,开关 (Comp.to BD138) [39KB]
BD138 PNP- 音频 功率放大,开关 (Comp.to BD137) [105KB]
BD139 NPN- 音频 功率放大,开关 (Comp.to BD140) [39KB]
BD140 PNP- 音频 功率放大,开关 (Comp.to BD139) [105KB]
BD162 NPN 音频 功率放大,开关 晶体管 [NTE152][22kb]
BD203 PNP- 音频 功率放大,开关 (Comp.to BD204)[NTE182][23KB]
BD204 PNP- 音频 功率放大,开关 (Comp.to BD203)[NTE183][23KB]
BD241C NPN-3 AMPERE POWER 晶体管 80, 100 VOLTS 40 WATTS (Comp.to BD242C)
[109kb]
BD242C PNP-3 AMPERE POWER 晶体管 80, 100 VOLTS 40 WATTS (Comp.to BD241C)[109kb]
BD243 NPN Epitaxial 硅 晶体管 [39kb]
BD249 NPN 硅 POWER 晶体管 [94KB]
BD250 PNP 硅 POWER 晶体管 [94KB]
BD375 NPN Epitaxial 硅 晶体管 (Comp.to BD376) [43KB]
BD376 PNP Epitaxial 硅 晶体管 (Comp.to BD375) [43KB]
BD377 NPN Epitaxial 硅 晶体管 (Comp.to BD378) [43KB]
BD378 PNP Epitaxial 硅 晶体管 (Comp.to BD377) [43KB]
BD379 NPN Epitaxial 硅 晶体管 (Comp.to BD380) [43KB]
BD380 PNP Epitaxial 硅 晶体管 (Comp.to BD379) [43KB]
BD543 NPN 硅 POWER 晶体管 [85KB]
BD529 NPN- 高电压放大、驱动(Comp. to BD530)[NTE188][23KB]
BD530 PNP- 高电压放大、驱动 (Comp. to BD529)[NTE189][23KB]
BD533 NPN 硅 POWER 晶体管 (Comp.to BD534) [45KB]
BD534 PNP 硅 POWER 晶体管 (Comp.to BD533) [45KB]
BD535 NPN 硅 POWER 晶体管 (Comp.to BD536) [45KB]
BD536 PNP 硅 POWER 晶体管 (Comp.to BD535) [45KB]
BD537 NPN 硅 POWER 晶体管 (Comp.to BD538) [45KB]
BD538 PNP 硅 POWER 晶体管 (Comp.to BD537) [45KB]
BD677 达林顿管, NPN-功率放大.(Comp. to BD678) [42KB]
BD678 达林顿管, PNP-功率放大.(Comp. to BD677) [42KB]
BD679 达林顿管, NPN-功率放大.(Comp. to BD680) [42KB]
BD680 达林顿管, PNP-功率放大.(Comp. to BD679) [42KB]
BD681 达林顿管, NPN-功率放大.(Comp. to BD682) [42KB]
BD682 达林顿管, PNP-功率放大.(Comp. to BD681) [42KB]
BD591 NPN 音频 功率输出、 中功率、开关[NTE196] [25KB]
BD592 PNP 音频 功率输出、 中功率、开关[NTE197] [25KB]
BDX53C NPN-硅 POWER DARLINGTON 晶体管 (Comp. to BDX54C) [81KB]
BDX54C PNP-硅 POWER DARLINGTON 晶体管 (Comp. to BDX53C) [81KB]
BDW51 NPN 硅 power 晶体管 [NTE60] [25KB]
BU208A 高电压、快速开关 NPN 功率晶体管 [84KB]
BU508A 高电压、快速开关 NPN 功率晶体管 [84KB]
MJ802 NPN-晶体管 大功率 音频 Amplifier (Comp. to MJ4502)[NTE][24kb]
MJ2955 PNP- 功率放大. (Comp. to 2N3055)
MJ4502 PNP-晶体管 大功率 音频 放大 (Comp. to MJ802)[NTE][24kb]
MJ15003 NPN- 功率放大. (Comp. to MJ15004) [120KB]
MJ15004 PNP- 功率放大. (Comp. to MJ15003) [120KB]
MJE340 NPN-中功率晶体管 (Comp. to MJE350) [67KB]
MJE350 PNP-中功率晶体管 (Comp. to MJE340) [70KB]
MJE15028 NPN POWER 晶体管 (Comp. to MJE15029) [218KB]
MJE15029 PNP POWER 晶体管 (Comp. to MJE15028) [218KB]
MJE15030 NPN POWER 晶体管 (Comp. to MJE15031) [218KB]
MJE15031 PNP POWER 晶体管 (Comp. to MJE15030) [218KB]
PMD16K100 达林顿管, NPN-功率放大.(Comp. to PMD17K100)[NTE251][27KB]
PMD17K100 达林顿管, PNP-功率放大.(Comp. to PMD16K100)[NTE252][27KB]
TIP31 NPN Epitaxial 硅 晶体管 (Comp. to TIP32) [38KB]
TIP32 PNP Epitaxial 硅 晶体管 (Comp. to TIP31) [38KB]
TIP122 NPN EPITAXIAL DARLINGTON 晶体管 [62KB]
TIP140 NPN 达林顿[复合]功率晶体管(Comp. toTIP145)[218KB]
TIP141 NPN 达林顿[复合]功率晶体管(Comp. toTIP146)[218KB]
TIP142 NPN 达林顿[复合]功率晶体管(Comp. toTIP147)[218KB]
TIP145 PNP 达林顿[复合]功率晶体管 (Comp. to TIP140)[218KB]
TIP146 PNP 达林顿[复合]功率晶体管 (Comp. to TIP141)[218KB]
TIP147 PNP 达林顿[复合]功率晶体管 (Comp. to TIP142)[218KB]
TIP2955 PNP- 功率放大. (Comp. to TIP3055)
TIP3055 NPN- 功率放大. (Comp. to TIP2955)
