进入-------方法1:按遥控器[ ]键,并保持4秒后,立刻按[MENU]键,屏幕上出现“TEST”。
方法2:短路主板TEST IN
退出-------按 [STANDBY]键,TV进入待机状态,再按[STANDBY]键,TV工作,此时已退出菜单。
选择调整项目及调整:进入工厂调整模式后,按数字键即可选择M0~M9 共10个工厂主菜单,再利用“P+”,“P+”两个键可上下改变调整项目,利用“V+”,“V-”两个键可调整数据。
附:厦华G295(G系列机心)数据和参数对照
| 显示符号 | 数据 | 显示符号 | 数据 |
| TEST SIGNAL | 00 | H.PHASE | 07 |
| SOND TRAP | 00 | H.WIDTH | 00 |
| ABL TH | 04 | EW.CORR | 00 |
| ABL TH | 00 | TRAP.CORR | 00 |
| TILE | OFF | EW.CORNER | 00 |
| SUPER RF | ON | PROGRAM | |
| AC OFF | OFF | CL | 32 |
| CLOCK | ON | BT | 48 |
| PAL | ON | CT | 48 |
| N3.58 | ON | SC | |
| N4.43 | ON | RB | 40 |
| SECAM | OFF | GB | 40 |
| 6.5M | ON | BB | 40 |
| 6.0M | ON | RD | 70 |
| 5.5M | OFF | GD | 06 |
| 4.5M | ON | DB | 70 |
| SIF PRI | D/K | SB | 90 |
| IF | 38MHz | RF AGC | 2.65-2.7 |
| AV2 | ON | H PL LEFT | 04 |
| S-VIDEO | ON | H BL RHCHT | 04 |
| LANGUAGE | ON | FBT.BLK.SW | 01 |
| WOOFER | ON | V COMP | 07 |
| SRS MODE | OFF | H FREQ | |
| BAND MODE | 01 | RG GAMMA | ON |
| POW ON MODE | 00 | B GAMMA | OFF |
| OSD CONT | 60 | R/B BALANCE | 07 |
| V.POSI | 18 | R/B ANGLE | 07 |
| V.SIZE | 48 | SECAM B-Y | 07 |
| V.LINE | 15 | SECAM R-Y | 07 |
| V.SC | 11 | FM GAIN | 00 |
| OSD POS | 01 | FM LEVEL | 31 |
| SPEED | 00 | VIDEO LEVEL | 07 |
| V.POS | 00 | SUB CONT | 108 |
| V.SIZE | 00 | SUB CONT | 71 |
| V.LINE | 00 | SUB SHARP | 63 |
| V.SC | 00 | SUB TINT | 31 |
