| 规格 | 型号 |
最大电压 (VDC) |
最大功耗 (mW) |
环境温度 (℃) |
光谱峰值 (nm) |
亮电阻 (10Lux) (KΩ) |
暗电阻 (MΩ) |
100 γ10 |
响应时间 mS |
照度电阻特性 | |
| 上升 | 下降 | ||||||||||
| Φ3系列 | GL3516 | 100 | 50 | -30~+70 | 540 | 5-10 | 0.6 | 0.5 | 30 | 30 | 2 |
| GL3526 | 100 | 50 | -30~+70 | 540 | 10-20 | 1 | 0.6 | 30 | 30 | 3 | |
| GL3537-1 | 100 | 50 | -30~+70 | 540 | 20-30 | 2 | 0.6 | 30 | 30 | 4 | |
| GL3537-2 | 100 | 50 | -30~+70 | 540 | 30-50 | 3 | 0.7 | 30 | 30 | 4 | |
| GL3547-1 | 100 | 50 | -30~+70 | 540 | 50-100 | 5 | 0.8 | 30 | 30 | 6 | |
| GL3547-2 | 100 | 50 | -30~+70 | 540 | 100-200 | 10 | 0.9 | 30 | 30 | 6 | |
| Φ4系列 | GL4516 | 150 | 50 | -30~+70 | 540 | 5-10 | 0.6 | 0.5 | 30 | 30 | 2 |
| GL4526 | 150 | 50 | -30~+70 | 540 | 10-20 | 1 | 0.6 | 30 | 30 | 3 | |
| GL4537-1 | 150 | 50 | -30~+70 | 540 | 20-30 | 2 | 0.7 | 30 | 30 | 4 | |
| GL4527-2 | 150 | 50 | -30~+70 | 540 | 30-50 | 3 | 0.8 | 30 | 30 | 4 | |
| GL4548-1 | 150 | 50 | -30~+70 | 540 | 50-100 | 5 | 0.8 | 30 | 30 | 6 | |
| GL4548-2 | 150 | 50 | -30~+70 | 540 | 100-200 | 10 | 0.9 | 30 | 30 | 6 | |
| Φ5系列 | GL5516 | 150 | 90 | -30~+70 | 540 | 5-10 | 0.5 | 0.5 | 30 | 30 | 2 |
| GL5528 | 150 | 100 | -30~+70 | 540 | 10-20 | 1 | 0.6 | 20 | 30 | 3 | |
| GL5537-1 | 150 | 100 | -30~+70 | 540 | 20-30 | 2 | 0.6 | 20 | 30 | 4 | |
| GL5537-2 | 150 | 100 | -30~+70 | 540 | 30-50 | 3 | 0.7 | 20 | 30 | 4 | |
| GL5539 | 150 | 100 | -30~+70 | 540 | 50-100 | 5 | 0.8 | 20 | 30 | 5 | |
| GL5549 | 150 | 100 | -30~+70 | 540 | 100-200 | 10 | 0.9 | 20 | 30 | 6 | |
| GL5606 | 150 | 100 | -30~+70 | 560 | 4-7 | 0.5 | 0.5 | 30 | 30 | 2 | |
| GL5616 | 150 | 100 | -30~+70 | 560 | 5-10 | 0.8 | 0.6 | 30 | 30 | 2 | |
| GL5626 | 150 | 100 | -30~+70 | 560 | 10-20 | 2 | 0.6 | 20 | 30 | 3 | |
| GL5637-1 | 150 | 100 | -30~+70 | 560 | 20-30 | 3 | 0.7 | 20 | 30 | 4 | |
| GL5637-2 | 150 | 100 | -30~+70 | 560 | 30-50 | 4 | 0.8 | 20 | 30 | 4 | |
| GL5639 | 150 | 100 | -30~+70 | 560 | 50-100 | 8 | 0.9 | 20 | 30 | 5 | |
| GL5649 | 150 | 100 | -30~+70 | 560 | 100-200 | 15 | 0.95 | 20 | 30 | 6 | |
| Φ7系列 | GL7516 | 150 | 100 | -30~+70 | 540 | 5-10 | 0.5 | 0.6 | 30 | 30 | 2 |
| GL7528 | 150 | 100 | -30~+70 | 540 | 10-20 | 1 | 0.6 | 30 | 30 | 3 | |
| GL7537-1 | 150 | 150 | -30~+70 | 560 | 20-30 | 2 | 0.7 | 30 | 30 | 4 | |
| GL7537-2 | 150 | 150 | -30~+70 | 560 | 30-50 | 4 | 0.8 | 30 | 30 | 4 | |
| GL7539 | 150 | 150 | -30~+70 | 560 | 50-100 | 8 | 0.8 | 30 | 30 | 6 | |
| Φ10系列 | GL10516 | 200 | 150 | -30~+70 | 560 | 5-10 | 1 | 0.6 | 30 | 30 | 3 |
| GL10528 | 200 | 150 | -30~+70 | 560 | 10-20 | 2 | 0.6 | 30 | 30 | 3 | |
| GL10537-1 | 200 | 150 | -30~+70 | 560 | 20-30 | 3 | 0.7 | 30 | 30 | 4 | |
| GL10537-2 | 200 | 150 | -30~+70 | 560 | 30-50 | 5 | 0.7 | 30 | 30 | 4 | |
| GL10539 | 250 | 200 | -30~+70 | 560 | 50-100 | 8 | 0.8 | 30 | 30 | 6 | |
| Φ12系列 | GL12516 | 250 | 200 | -30~+70 | 560 | 5-10 | 1 | 0.6 | 30 | 30 | 3 |
| GL12528 | 250 | 200 | -30~+70 | 560 | 10-20 | 2 | 0.6 | 30 | 30 | 3 | |
| GL12537-1 | 250 | 200 | -30~+70 | 560 | 20-30 | 3 | 0.7 | 30 | 30 | 4 | |
| GL12537-2 | 250 | 200 | -30~+70 | 560 | 30-50 | 5 | 0.7 | 30 | 30 | 4 | |
| GL12539 | 250 | 200 | -30~+70 | 560 | 50-100 | 8 | 0.8 | 30 | 30 | 6 | |
| Φ20系列 | GL20516 | 500 | 500 | -30~+70 | 560 | 5-10 | 1 | 0.6 | 30 | 30 | 3 |
| GL20528 | 500 | 500 | -30~+70 | 560 | 10-20 | 2 | 0.6 | 30 | 30 | 3 | |
| GL20537-1 | 500 | 500 | -30~+70 | 560 | 20-30 | 3 | 0.7 | 30 | 30 | 4 | |
| GL20537-2 | 500 | 500 | -30~+70 | 560 | 30-50 | 5 | 0.7 | 30 | 30 | 4 | |
| GL20539 | 500 | 500 | -30~+70 | 560 | 50-100 | 8 | 0.8 | 30 | 30 | 6 | |
